WD 12-Volt Conversion
AC-man
11-08-2004 12:38:08
I have owned my WD for years now. Good thing I have a hand crank to start it. I have gone thru several 6v batteries over the years. I am looking for a schematic for a 12v conversion. Please include all details....Thanks.
Steve in N.J.
11-13-2004 20:05:07
 Re: WD 12-Volt Conversion in reply to AC-man, 11-08-2004 12:38:08
AC,
We offer a nice 12V conversion system kit that gives you soup to nuts. Drop us a line if interested...
Steve/B&B Custom Circuits
Duey (IA)
11-10-2004 15:06:17
AC-man,
Check out the diagrams and info on my web site
Earle (NC)
11-10-2004 16:19:50
 Re: WD 12-Volt Conversion in reply to Duey (IA), 11-10-2004 15:06:17
Follow Duey's drawing and you won't have any problems.
Earle (NC)
11-10-2004 16:23:06
 Re: WD 12-Volt Conversion in reply to Earle (NC), 11-10-2004 16:19:50
I'm not saying the others are good also.
Earle (NC)
11-10-2004 16:24:43
 Re: WD 12-Volt Conversion in reply to Earle (NC), 11-10-2004 16:23:06
It should have read AREN'T good-they probably are
Brian G. NY
11-09-2004 17:27:16
A wealth of info right here on this site! Click on "Articles" under "Research and Info" on the LH side of this screen. Go to "Maintenance and Mechanical Information" and scroll down to a couple of different items relating to your question. BTW, I"ve converted 2 WDs and a "45" to 12 volts, but I did it the "hard way"; used all Ford parts. LOL Well,.... that"s all I had lying around; I"m a Ford fan as well as A-C.
steve(ill)
11-08-2004 15:08:51
you can install a 12 volt genertor and new voltage regulator, or better, just convert to a 12 volt alternator with internal regulator. the 10SI delco from mid 1975-85 is most common. i have a diagram for both gen and alter. spotter@frontiernet.net
