WD45 hanging up in gear
Ac orange
11-10-2004 07:34:49
What is the best way to take care of this problem?
bw in mo
11-10-2004 17:32:40
 Re: WD45 hanging up in gear in reply to Ac orange, 11-10-2004 07:34:49
Pull shift leaver out build end up 1/8" on the flat sides, most time problem solved. Yes the pins & top retainer ring &snap ring need to be checked.
John (C-IL)
11-10-2004 08:38:21
Hanging up in gear is actually the symptom of the problem. The causes are (in no particular order) worn shifter, worn shifter guide pin, weak or missing conical washer/snap ring, worn shift collars and worn bearings. Once you have identified the cause of the problem we can reccommend a solution.
Scott-IA
11-10-2004 08:36:02
Please expand some. Is the gear shift hanging up? Tranny locking up? Rear wheels locking up on occation?
More info needed.
AC orange
11-10-2004 17:12:26
 Re: WD45 hanging up in gear in reply to Scott-IA, 11-10-2004 08:36:02
The transmission is in second gear,and the end of the shifter is out the shifter forks.
