Steering adjustments on Model C
augie584
11-16-2004 15:31:31
Took this newly purchased Model "C" out for a test drive and found out that the tricycle front end had an extremely lot of play on paved surface. Is there any way to tighten up the steering ? A friend of mine advised to remove the metal shims located on top of the pedestal. TWe took it apart and found 2 metal shims but haven"t had time to reassemble yet. Just wondering if there are any other tricks to this.
Ted Seifert
11-17-2004 09:34:59
 Re: Steering adjustments on Model C in reply to augie584, 11-16-2004 15:31:31
The first course of action is to find out wgere the play is. It may be at the steering gear box at the end of the steering wheel shaft. If it is a Ross gear box there is an adjusting screw behind the starter. Ther are shims in the fromt gear box . If you tackle that get a service manual. The bearings may be bad.
