CA starter into WD????
Alan in WI
11-23-2004 07:18:09
Will the starter out of a CA work in the WD I am fixing up??? The dimensions appear to be similar and the only difference that I can find is the starter model number. The CA takes a different rebiuld kit so are there some internal differances that would make the CA starter not work in my WD???
Thanks in advance,
Alan
Jerry Coulter
11-23-2004 19:24:53
 Re: CA starter into WD???? in reply to Alan in WI, 11-23-2004 07:18:09
Won't fit. WD uses a 4 pole field while WC, B, C, & CA uses a 2 pole field. This gives WD more cranking power. The bendix drive on the WC & WD has fewer teeth hence smaller diameter, again gives more cranking power to the larger engine. B & C use the same drive end housing, other tractors each have a different one.
Alan in WI
11-24-2004 07:24:59
 Re: CA starter into WD???? in reply to Jerry Coulter, 11-23-2004 19:24:53
Thanks for the quick response, we'll have to try something different.
Alan
ACBOB
11-24-2004 18:50:24
 Re: CA starter into WD???? in reply to Alan in WI, 11-24-2004 07:24:59
I USED A CA STARTER IN A WC BY SWAPPING THE BENDIX UNITS. WORKED FINE. BOB
