7030 Allis Chamber will not pull
audirsj
11-27-2004 18:45:23
Transmission will go in grear but when clutch
is out, tractor will not move. Any help will be appreciated. Thanks.
sid s
11-28-2004 18:10:20
 Re: 7030 Allis Chamber will not pull in reply to audirsj, 11-27-2004 18:45:23
First make sure that the range transmission is going in gear. Somtimes the cable linkage can slip out of a clamp in the housing at the upper or lower end, or one of the ends of the cable may be broken off. Next do you have any hydraulic functions? Just power steering is all that it needs to be. If you have hydraulics, then the torque limitor is most likely good. If the tractor will still not move then the next possibility is that the hub of the power director clutch is stripped in the splines. For this repair you will need to split the tractor behind the engine and repair the clutch.
ANON.
11-28-2004 14:02:35
Sounds like the limiting disc is bad. There is a way to check it but I don't quite remember now.You will have to split it to change it, not that bad of a job.
