Need help pulling sleeves -wd45
53wd45
12-03-2004 17:09:44
Did a search here and found good info. Cobbled up a puller and started pounding. Not even a hint of movement. Even sprayed 'rust buster' down the waterways. What next? fff powder and a fuse? Would heat help out, I'm going to replace the O-rings anyway? Thanks in advance for ANY help!
acorange
12-07-2004 11:30:20
 Re: Need help pulling sleeves -wd45 in reply to 53wd45, 12-03-2004 17:09:44
The welding trick as described by "tramway guy"
works well.
It keeps sleeve puller tension down as well so as
not to ruin the tool from trying to pull a stuck
sleeve.
THANKS!
12-04-2004 16:08:00
Thanks for the info! I'll get a chance to try these techniques out in a couple of weeks and let you know how it works. Keith/Or, I'll send an email. Thanks again!
Keoth-OR
12-03-2004 22:06:46
Email me and I will send you pictures and details on how made my home made sleeve puller.
Keith in Gods country
Keith-OR
12-04-2004 13:41:50
 Sorry About Email !!!!! in reply to Keoth-OR, 12-03-2004 22:06:46
Thought I had my email made available to all, guess that is what I get for thinking. Some days it does not pay to get out of bed. Must be "OLD TIMERS DISEASE!!" whaya think? LMAO.
CHALMERSBOB
12-03-2004 20:23:21
I USED A HYDRALIC JACK COUPLED TO 2 LONG 3/8" REDIBOLTS. WORKED SLICK. PUT BAR ACROSS THE BOTTOM AND ANOTHER ABOVE THE JACK.
HAD TRIED BLOCK OF WOOD WITH SLEDGE HAMMER FOR WEEKS, BUT COULDN'T MOVE THEM. USED JACK AND HAD THEM OUT IN 30 MINUTES
LOL BOB
Tramway Guy
12-03-2004 17:56:57
If you are going to throw them away anyway, try, welding a heavy bead around the inside. When they cool off, they will shrink a little and will come out a lot easier.
Be careful not to burn through it,though!
wdTom
12-03-2004 17:14:37
I had to use a sledge hammer along with a puller on the ones in my WD. That had sat for 25 years though with no antifreeze. Just air and dampness, they were STUCK.
Ol Chief
12-04-2004 18:21:50
 Re: Need help pulling sleeves -wd45 in reply to wdTom, 12-03-2004 17:14:37
Put some Dry Ice inside (frozen CO 2)Couple hundred Degrees below Zero.Dhen pull with no damage.
