WD foot clutch thump noise ?
Alberta Mike
12-12-2004 06:32:30
A friend of mine has a WD45 Allis and when you depress the foot clutch, right before the pedal bottoms out to full disengagement, you hear (and feel) sort of a dull thud or blunt clunking sound. Doesn't seem to affect how it works, it releases and works fine, but that noise/feel definitely isn't right. Any ideas where the problem might lie?
Dave in Florida
12-20-2004 11:24:20
 Re: WD foot clutch thump noise ? in reply to Alberta Mike, 12-12-2004 06:32:30
I would also say a bad throw out bearing. You gotta keep em greased. Small plate under clutch housing, remove, lock clutch pedal forward, hit her with a grease gun (zerk fitting).
Dave
Kent of SW MO
12-14-2004 06:37:15
Bad throw out bearing.
Kent
wdTom
12-12-2004 18:02:23
Possibly some loose linkage, maybe in the clutch housing. Loose set screw or some such??
