Allis B Main Bearing Question
Arkansas Bill
12-23-2004 14:58:09
I am putting an Allis B engine together and am ready to "wire" the main bearing bolts. What quality/type/strength wire should be used? Would ordinary tie wire be okay? I understand the technique used and that is used extensively in the aircraft field. Merry Christmas to all Arkansas Bill
Arkansas Bill
12-24-2004 05:05:27
 Re: Allis B Main Bearing Question in reply to Arkansas Bill, 12-23-2004 14:58:09
Steve and M. J. T. Thanks for the response. It is really neat (for an old grease monkey wannabe like me working on an ancient machine) to be able to find answers to questions so quickly. Thank you and Merry Christmas,
Bill
M.J.T.
12-23-2004 17:09:17
I Used Stainless Steel Tie wire, Largest Diameter That Would Fit. It is Very Important To Get It Tight so it does not flip flop around as the crankshaft spins.
steve(ill)
12-23-2004 19:03:10
 Re: Allis B Main Bearing Question in reply to M.J.T., 12-23-2004 17:09:17
regular soft bailing wire is adequate. dont want it too hard where is cracks and breaks under vibration. as MT said, twist it snug so it dont rattle. you know the lay of the warap is important. as the bolt trys to loosen it should tighten the wire, not get any extra play.
