WD What does it weigh?
andcarst
12-27-2004 18:52:18
I am buying a WD and need to know how much it weighs so I can know what I will need for a trailer to huaql it.
12-28-2004 10:17:11
 Re: WD What does it weigh? in reply to andcarst, 12-27-2004 18:52:18
Around 4000lbs.I use a 2 axle 16ft with 3500lb axles.Be careful if not using trailor brakes,good luck!
Kevin (FL)
12-28-2004 06:15:15
Somewhere between 3700 & 4000 #'s. Add more for weights or water ballast. Check rear tire spread as they can get pretty wide, but it should have power-shift wheels.
