Allis B chiped piston
Andrew Z
02-03-2005 10:08:05
Another bump in the road has come up. On one of the pistons the oil ring had frozen to the pistion. So being dumb I tryed to wedge it off with a srew drive and I broke a chip off one of the groves. The grove right above the oil ring the piece is about 1/2" or so. Do I need a new piston or is it still safe to use? Thanks for the help!
Andrew
Dick L
02-04-2005 06:04:59
 Re: Allis B chiped piston in reply to Andrew Z , 02-03-2005 10:08:05
Make sure you get a piston the correct size if you are getting a used one. I have picked up used pistons from time to time but take my calipers as well as the old piston with me. I have some that you could have if they could be or would match your old one.
Roger VanCamp has them but I pick out the pistons I buy from him myself.
steve(ill)
02-03-2005 17:35:21
talk to one of the used parts vendors on the allischalmers dot com site. several of them have used parts for AC tractors.. if you cant get there from here, send me an e-mail spotter@frontiernet.net
old
02-03-2005 10:52:18
New piston, other wise you will probably end up with problems in that cylinder.
Andrew Z
02-03-2005 10:54:35
 Re: Allis B chiped piston in reply to old, 02-03-2005 10:52:18
any idea were I can get a used piston?
old
02-03-2005 11:16:21
 Re: Allis B chiped piston in reply to Andrew Z , 02-03-2005 10:54:35
I'd try value bitl
