Allis B its almost there!! oil break in question
Andrew in CT
02-07-2005 08:57:04
Should I use a heavy weight oil to break the engine in? or just the oil I plan to run in her (10W - 30)??
Thanks for all the help!! Andrew
Gordon in IN
02-07-2005 18:51:03
 Re: Allis B its almost there!! oil break in questi in reply to Andrew in CT , 02-07-2005 08:57:04
There are sure to be lots of different opinions on this subject. I have run straight 10W standard (non synthetic) API/SAE (high detergent) rated oil for inital "run in". I also pressurize the oil lines, galleries,rocker arms and bearings with oil before starting the engine by "pumping" at least three quarts of oil into the engine through the oil lines/galleries. After the engine is "run in", I like to use 10W-30 or 10W-40 Synthetic Oil(depending on the engine bearing clearances)(It sure makes starting the engine in cold weather EASY.) I have also used 10W-30 standard oil for "run in", but it did seem to take longer for the rings to seat/seal. I have heard that there is a "run in" or "break in" oil available that is used by some engine rebuilders. I cannot confirm this and do not know where any such "break in" oil is available. I do NOT think it is recommended to use synthetic oil for "run in" of a new or rebuilt engine. Are there any other opinions or personal experiences concerning using synthetic oil for "run in"?
BushogPapa
02-07-2005 13:13:35
I like to use a medium quality oil like Valvoline for break-in..10-30 is good.. Then, when the engine is well broken-in, I change to Castrol 10-40...
Ron..
Steve in N.J.
02-07-2005 09:27:02
Andy,
Personally, I don't think it's neccessary to run a heavier wieght oil for new engine break-in. When I restored my B, I've been using 10w-40 in it since the engine's been done with no problems. You could run some hours on your oil of choice, then dump it and add new oil & filter just to get any break-in debris out. That's what I did. Been going for 4 years now, and runs fine. Good Luck with your B, they're a great little machine...!
Steve/B&B Custom Circuits
steve(ill)
02-07-2005 16:23:31
 Re: Allis B its almost there!! oil break in questi in reply to Steve in N.J., 02-07-2005 09:27:02
im with STEVE, dont change brands, just change the oil and filter after the first 20 hours running. i personally like the 10w30.
