AC B Surging
Aaron
06-22-1999 11:27:19
I have a '47 model B with a 5' Woods belly mower. I use it to mow approx 4 acres and it runs pretty good (mows great). The governor surges just a little bit at full throttle under this kind of load, however, without any PTO load it gets a lot worse. It seems to idle OK, misses only a little. The gov weights are in pretty good shape and I replaced the points and condensor and rebuilt the carb when I bought it a year ago. Any helpful hints would be appreciated.
Walt
06-22-1999 16:03:06
 Re: AC B Surging in reply to Aaron, 06-22-1999 11:27:19
Check the rod between the carb. and the governor lever for a spring. This spring hooks into a small hole in the center of the rod. If the spring is gone or unhooked, it could cause the surging problem.
William Powell
06-23-1999 11:20:46
 Re: Re: AC B Surging in reply to Walt, 06-22-1999 16:03:06
Ditto on the spring. Very common to see them missing.
William Powell
06-23-1999 11:20:32
