CA oil pressure
Arkansas AC/CA
02-26-2005 14:45:00
Hello, I got my CA running today after I changed the oil, filter and manifold. It did not have any oil pressure when I started it again. I took the oil pressure guage off and cranked it over, and WATER came out of the hole. I did replace with an Agco filter, so I know th filter is th correct one.
WHAT GIVES HERE????
Let me know what you think!
THANKS!!!
Bill
Arkansas AC/CA
02-27-2005 10:03:39
 Re: CA oil pressure in reply to Arkansas AC/CA, 02-26-2005 14:45:00
OK, thanks for the help, I found the problem. It is one of the casting plugs in the head. Boy was I relieved. Just a little hole, but it was leaking like crazy.
THANKS AGAIN!
Arkansas AC/CA
02-26-2005 19:20:03
Jay, thanks for the response. The old oil did have water in it, but I thought it was from a poorly fitting exhaust pipe. It has not been freezing here. I took out my drain plug, and LOTS of water came out. I just read about the casting plugs in the head, and pulled my valve cover off. I don't think that they are leaking. What else could it be? I did not see any white smoke in the exhaust, so I do not think that water is getting into my cylinders.
jayw
02-26-2005 21:08:47
 Re: CA oil pressure in reply to Arkansas AC/CA, 02-26-2005 19:20:03
Did your tractor have the wrong exhaust pipe and muffler, it is important too have the right one for a CA it is the one that bolts too the side of the manifold.If they had the wrong one it could have very well let water in, That is what happened too mine when I got it. I had too clean my engine out with a flush of Kerosene 2 times them put oil in and ran for a hour then change the oil again.If you still see a milky oil Tom is right pull the pan off and look for water around the sleves.You may be lucky and it just be the wrong exhaust.
wdtom
02-26-2005 20:28:56
If the head plugs are not leaking it is possible the leak is around the bottom of the liners where they seal to the block, O rings. Or it could be a cracked block. You may be able to see if you pull the pan, if it is a slow leak though it may be difficult.
jayw
02-26-2005 16:35:10
2 questions #1 did the old oil have water in it,#2 has it been freezing there were your at.
If old oil; had water you have other problems , if its been freezing ther you could of had some condensation freeze at the filter housing an it thawed and can out .
