mounting weights?
770jdman
03-13-2005 05:51:44
Uncle bought a B. Trying to figure out how the front side weights mount. see where the back hole mounts but is there a special pin or dowel that goes in the end of the weight to the front casting to hold it up in the front.
Herb
03-16-2005 10:54:36
 Re: mounting weights? in reply to 770jdman, 03-13-2005 05:51:44
piece of 3/4 pipe cut to the right length makes a good replacement with the right bolt.
Rod (NH)
03-13-2005 09:30:08
Hi,
Yes, there is a "dowel" that needs to be mounted to the front plate:
third party image
It's about 1-1/4" long and of a diameter that gives a loose fit in the hole at the front of the weights. It's held to the front plate by a 1/2" dia bolt as shown.
third party image Rod
