D-17 clutch oil in trans PLEASE HELP!
ac john
04-21-2005 11:47:13
THe powerderector oil is ending up in the trans.
Does anyone know what is wrong?
Thanks. John
Gordon Chance
04-23-2005 18:55:46
 Re: D-17 clutch oil in trans PLEASE HELP! in reply to ac john, 04-21-2005 11:47:13
Check the fill plug for the power director/ hydraulics compartment for a plugged vent. If the vent is plugged it will build pressure in the compartment as the oil heats up and push oil past the PTO seals or input shaft seal into the transmission.
Gordon
Texas Denny
04-22-2005 09:06:23
I'm not sure I'm disagreeing with Gatz or AC John or not. I just had a problem with the hydraulic fluid getting in the transmission of my D-17 Series II. It was a result of bad seals on the cylinder. But as I recall, a Series IV has external cylinders. If they leak, it goes on the ground. If it is the power director oil getting in the transmission, doesn't it have to be a seal between the power director and the transmission?
Gatz
04-21-2005 17:34:57
What series D17 ?
If you're referring to the combined PD/hydraulic oil on an earlier D17 (not SerIV, or some SerIII),
usually, it's either a leaking lift arm cylinder inside the rear housing, OR a leaking or ruptured hose going to the cylinder.
Either one requires the removal of the lift-arm housing. You'll have to remove the pto shaft first, so might as well drain out all the oil from xmsn and PD/hyd.
Be careful!!when pulling the PTO shaft out so as not to damage the seals (there are 2 of them back-to-back at the front of the xmsn casting)
There's also the possibility that the PTO seals themselves are leaking, however; the fluid levels would be about the same from the PD/hyd to the xmsn.
Gatz
Gatz
04-21-2005 17:52:15
 Re: D-17 clutch oil in trans PLEASE HELP! in reply to Gatz, 04-21-2005 17:34:57
Forgot to add..... you'll need a new gasket for that housing.
ac john
04-21-2005 20:34:17
 Re: D-17 clutch oil in trans PLEASE HELP! in reply to Gatz, 04-21-2005 17:52:15
I forgot to mention it is a series IV.
