Allis B manifold
Andrew Z
05-03-2005 06:23:30
On My 38 B the manifoild is in good condition. however there is no pipe comming out of the manifold. The muffler itself fits loose in the manifold. Also I think it blocks some of the passeges. And one other thing does anyone think that the 1 1/2" muffler is to small for that size engine? Anyone tried to put on a 2" one on
Thanks for the help Andrew
Texas Denny
05-03-2005 07:58:07
 Re: Allis B manifold in reply to Andrew Z , 05-03-2005 06:23:30
I had the same problem on my C. The hole was too big. I found some very thin sheet metal and cut it 1" wide and wrapped it around the muffler and then shoved it in the hole. I had to shorten the shim several times until I got it right but I finally was able to force the thing together. It seems to be holding fine. I need to make the bracket for the muffler support but it doesn't seem to need it. You are right, you can push it in too far - 1" to 1.5" max. The standard muffler is fine. This is a small engine.
