1957 D-14
allislover
05-18-2005 08:39:43
I need to get a new muffler for my D-14. What size is the outlet on my exhaust manifold? Question # 2- Tractor was missing out pretty bad when mowing, I replaced plugs/wires and dis. cap, that seemed to help but still not running top notch. What now?
Texas Denny
05-20-2005 20:32:58
 Re: 1957 D-14 in reply to allislover, 05-18-2005 08:39:43
Tractor Supply has a catalog for tractor mufflers. Look up your tractor and the catalog will tell you which muffler to use. Or you could try Ebay but TSC has been about the same in price.
Did you change the rotor, points and condensor? If you haven't, the tuneup is not complete. After changing them, place a mark on the distributor so you know where it was before any adjustments are made. While the engine is running at idle, loosen the distributor bolts and rotate the distributor first one way and then the other. Don't rotate so far in either direction that the engine stalls. Find the position where tractor labors the least. Then try the tractor again.
Also, some Allis's are kind of partial to certain kinds of plugs. I have a WD that misses with new Champions but is delighted with old AC. I had to use the new Champions in a C which was happy with them.
