D15 Info needed
acowner
06-20-2005 13:46:16
I am looking to buy a AC D15 tractor. The tractor appears in good mechanical condition. The tires are fairly good and the paint and sheet metal are very good being just a little faded. I was wondering if anyone knows about what a good D15 would bring and also is there any common promblems with the D15 I should look for. It had a diesel engine series II, but has been changed out with a gas D15 engine. The tractor is located in Tennessee. Thanks
alliswd45
06-25-2005 18:32:57
 Re: D15 Info needed in reply to acowner, 06-20-2005 13:46:16
Yeah the D15 would bring at least 1000 dollars here in Virginia and the moast you would probably pay should be about 2500 if a dealership doesnt own it. If not just find the book price on it.
dej(JED)
06-23-2005 07:45:52
I have a D 15 and I feel that it is underpowered. It starts right up, but just doesn't seem to have much in the way of go power under a load.
Dale(MO)
06-21-2005 01:54:53
There is one for sale in a local paper in mid-Missouri for $3995 (dealership). That is usually about what they go for around here, in the condition you describe.
As far as things to look for, I know that you should make sure the transmission doesn't jump out of gear. They have a constant-mesh tranny, and people were bad to grind them into gear. I have heard 3rd was usually what went out first, but I would be sure and put it under a decent load in each gear (uphill and downhill) before I did anything else.
As far as going from diesel to gas, it could be considered an improvement. The gassers had a little more power, and unless the diesel was in good shape - with a new or rebuilt injector pump -the gasser will undoubtedly start better, no matter the weather. Hope this helps.
Good luck,
Dale
