AC model C oil type
Allis Farmer
06-23-2005 21:03:14
I have almost finished restoring my first tractor. It is a 1945 Allis Chalmers model C. I don't know what kind of oil to put into the oil sump, transmisson and differential, and the final drive. What type of oil should I use for each part?
Texas Denny
06-25-2005 07:00:57
 Re: AC model C oil type in reply to Allis Farmer, 06-23-2005 21:03:14
Engine oil was 30 weight in summer and 10 weight in cold weather. I use 20W50 with good results. The transmission/differential requires 30 W non-detergent if you have the optional hydraulics. Non-detergent is often called motor oil but don't use it in the motor. If you don't have hydraulics, use 80W gear oil or heavier. For the final drives, use 80W gear oil or heavier.
