new to Model B questions (2)
ACIdaho
06-24-2005 14:26:26
I recently bought a nice 1949 Model B and would like to know what HP the engine is rated at, and what I might try to get the hydraulics working? Thanx much in advance, Chuck
wdtom
06-24-2005 17:09:17
 Re: new to Model B questions (2) in reply to ACIdaho, 06-24-2005 14:26:26
If I remember the HP is around 23. Hydraulics- did you engage the PTO?
ACIdaho
06-26-2005 19:11:30
 Re: new to Model B questions (2) in reply to wdtom, 06-24-2005 17:09:17
engaged PTO, operated hydraulic pump lever....very noisy pump (clacking), hoses twitched, oil oozed from right piston.
PS I have a 3 point conversion arriving Wednesday...probably need to start lookong for a pump?? Chuck
steve(ill)
06-27-2005 20:03:36
 Re: new to Model B questions (2) in reply to ACIdaho, 06-26-2005 19:11:30
pump and valve are a combo unit. might just have crud and or water in it. should be a 1/4 inch pipe plug near the top on the back side where the hose comes out to the cylinder. take the hose off and try bumping the lever with PTO running. see if it drools or squirts out. dont worry, it only pumps a gallon or two a minute. pump out a quart or two and see it if looks better. if it dont work, it is not hard to rebuild the pump/ valve combo, but you need a book or someone that has done it before. 4 little springs that can break, 4 chekc balls to keep the "hold" position, and a relief ball. not difficult after you see it done once.--- are you using thin oil, hytrans or 20 wt??
ACIdaho
06-24-2005 20:32:11
I don"t know if I tried the hydraulics when I was running the PTO....I see where you"re going and will try it tomorrow! Thanx much, Chuck
