rust in sediment bowel....runs good
ACIdaho
07-06-2005 20:06:48
for 15 minutes after cleaning carb (Marvel), sputters dies. What is the best approach for cleanic the tank....use a magnet? Is there a filter that works with gravity feed? Thanx much Chuck
Dave NE IA
07-13-2005 19:08:40
 Re: rust in sediment bowel....runs good in reply to ACIdaho, 07-06-2005 20:06:48
Perhaps just a little good luck for me, but 6 gallons of white viniger @ $2.50 worked better than any sandblasting, power washer, rocks / cement mixer combination I have ever used the last 40 years. Let it sit for 3 days then flush with clean water. It looks sandblasted when you get done. A tank sealer would be recomended for sure to keep if from rusting again. Dave NE IA
payne
07-10-2005 05:34:36
just get a piece of brake line grind one end cut it about 1 inch tall and stick it in your sediment bowl works great cheap easy fix
souNdguy
07-07-2005 20:42:54
A lawnmower fuel filter is designed for gravity feed..
Soundguy
JMS/MN
07-06-2005 21:05:16
Auto parts stores should have a filter than can be put in-line. Maybe Fram HG4?. I know I have a couple in the shop- comes in an orange box, has about quarter inch hoses and clamps in the kit. Needed them when methanol (NOT ethanol) first showed up around here and the p/u fuel tank released all of the tank residue. Have bought a WD or two with the fuel line cut and had those filters installed.
