Radiator Gaskets for M crawler?
Andy in Manteca
07-25-2005 11:35:08
Does any body make them? I did a search with no results.
Thanks,
Andy
Andy in Manteca
08-11-2005 11:57:55
 Re: Radiator Gaskets for M crawler? in reply to Andy in Manteca, 07-25-2005 11:35:08
Thanks Pete, I found a place that makes them for $33. but they want $15 dollars for shipping?
I might take your advice and give it a try.
what did you use to punch the holes out for the bolts?
Pete in Cal
08-11-2005 17:02:52
 Re: Radiator Gaskets for M crawler? in reply to Andy in Manteca, 08-11-2005 11:57:55
Andy, I used a pen to mark the holes thru the tank castings which also helps to keep the material flat. Then used a utility knife or exacto to cut out the holes. I have also used a ball pein hammer to gently tap the material into the hole and cut out the indented portion. Gently does it so as to not damage the tank. I was also careful to tighten the bolts evenly during assembly. Good luck, Pete
Andy in Manteca
08-11-2005 19:30:36
 Re: Radiator Gaskets for M crawler? in reply to Pete in Cal, 08-11-2005 17:02:52
Thanks Pete, I'll give it a shot over the weekend!! Andy
Pete in Cal
08-09-2005 13:49:16
Andy, I made my own since I couldn't locate a supplier. Not hard to do with sheet cork or other gasket material. I had some cork so used it, but coated it with water-proof grease like plumbers use, on all sides and edges. Otherwise it will seep. Worked fine on my M. Pete
