WD voltage regulator
almostdone
07-28-2005 14:57:58
I have a 1948 wd that has a 12 volt battery, mag. altenator and a voltage regulator. It looks like the original voltage reg. and is all corroded and not working. My question. Should I go back with the original voltage reg. and will it work with a 12 volt altenator? I couldn"t find anything in my manual covering the voltage reg.
Thanks for your help.
steve(ill)
07-28-2005 18:14:35
 Re: WD voltage regulator in reply to almostdone, 07-28-2005 14:57:58
the guys are right. the tractor had a generator with 6 volt regulator when it was new. a generator is 5 inches in diameter and about 10 inches long and steel. --- it might have been updated to an alternator. an alternatro was built after 1965 and has an aluminum housing, about 6 incehs diameter and 6 inches long. Some are 6 volt, some are 12 volt. some have voltage regulators inside if they were built after 1975-80. You need to figure out what you got and if it needs a regulator. look for a name or model number, or better, take it to NAPA and give it to them and ask for a DELCO 10SI off a 1975 chevy truck and install it. it will have an internal voltage regulator and you are good to go.
Duey (IA)
07-28-2005 17:23:23
First you must determine if the alternator already has an internal regulator. Possibly you have a system that had a regulator installed for a 6 volt generator and then a alternator installed to replace the generator.
If that's the case, start from scratch and rewire for what you have.
I have some diagrams on my website that may be of some help.
almostdone
07-29-2005 12:49:16
 Re: WD voltage regulator in reply to Duey (IA), 07-28-2005 17:23:23
I appreciate the information you have provided and I can handle it from here, I think. The diagrams are great and will be of great help.
old
07-28-2005 15:25:54
If it has an alternator on it thats not facory from the factory it would have had a genny on it.
