WD45
alex7407
07-29-2005 19:43:39
Correct me if im wrong, but the serial number on a WD45 is supposed to be just behind the left brake cover. Mine doesn't have one. Could someone have sanded it off, or something like that?
JMS/MN
07-30-2005 08:46:59
 Re: WD45 in reply to alex7407, 07-29-2005 19:43:39
The number is stamped on the rear vertical face of the left brake housing. Should be a hole nearby with a brake spring hooked in it. WD45s start at #146607.
big jt
07-30-2005 00:52:48
Might be painted over real thick. The number is stamped in the back of the left brake housing cover. NO plate just stamped.
HTH
jt
Sid
07-29-2005 21:05:34
Try looking on top left differential brake housing.
JMS/MN
07-30-2005 16:48:27
 Re: WD45 in reply to Sid, 07-29-2005 21:05:34
If you have the WD operator manual, it does show the serial number there, (4004), on TOP of the housing, as well as on the rear vertical face of the housing, but the number on the rear face is where every tractor number is located. Early ones may have it twice.
Sid
07-29-2005 21:05:24
Sid
07-29-2005 21:05:00
Sid
07-29-2005 21:04:50
