timed running probs with 4' King Kutter....
ACIdaho
08-06-2005 17:25:40
I make a couple of passes on my pasture and B begins to sputter/backfire and dies (aways at nearly the same spot...like a Bermuda Triangle!). Four days in a row. Runs good at each start. HELP!
Ted Seifert
08-07-2005 19:50:14
 Re: timed running probs with 4' King Kutter.... in reply to ACIdaho, 08-06-2005 17:25:40
This is a fuel problem (been there ) Take the gas tank off and wash it outwith keroscene for safety. Also be sure you have enough gas, as some tanks have a riser tube in the top of the fuel bowel to keep junk from the bottom of the gas tank out, however it also does not allow you to use the last 1/2 inch of gas in the tank.
gene (Missouri)
08-06-2005 18:47:56
Fuel supply problem, Ignition problem:
Do you have to wait 30 to 60 minutes or more before the tractor will restart? - coil. Does the tractor start up in a few minutes? - then fuel problem.
Next time the tractor dies check the spark at one of the plugs.
