Snap Coupler
alex7407
09-01-2005 18:07:59
After dismantiling my WD45, I can't remember out how to reassemble the snap coupler assembly. Could someone send me a drawing or explain this to me.
JMS/MN
09-02-2005 10:42:38
 Re: Snap Coupler in reply to alex7407, 09-01-2005 18:07:59
Since no one sent a picture yet, and I can't- here is the verbal answer: Assuming you are having trouble getting the spring installed properly in the bell housing- the two ends of the spring are on top, facing forward. The curved portion goes down, and around to the front. Slide the spring around the hook so the ends of the spring are up and forward, and the curved portion of the spring is around the front area of the hook, below the hole. Insert this assembly into the bell from the bottom. The hook should be in the proper position within the bell and the two spring ends will be sticking out the top forward portion of the bell weldment, near where the trip lever chain passes through. The pin that latches everything to the tractor will hold everything in place. There is a cross pin in the weldment, and the trip lever chain passes in front of that pin. The two spring ends reast against that pin.
