ac wd45 engine speed problem
Andrew K
09-12-2005 19:11:37
ON my wd 45 you can start the tractor and it will idle fine but as soon as you crack the throttle to about half the engine runs away and races way about stock rpms. what happened did the weights or something break inside thakns for any advice
Texas Denny
09-12-2005 20:08:34
 Re: ac wd45 engine speed problem in reply to Andrew K, 09-12-2005 19:11:37
Something is definitely wrong with your govenor. Weights might be the problem or maybe linkage. You'll have to pull it off and do a thorough inspection. Come back with your findings.
