226 aills engine rebuild HELP !
1morgan
09-20-2005 19:26:13
I have a 226 ci. E-gleaner motor, and was told I could put in 4.125 piston and sleeve set for wd. and get more compresion. Will this work? If so what else should I do to finish up this motor? Am planing to pull this tractor. Was also told I could use chevy pistons. If the WD. pistons work what kind of compression would I get, and H.P.? Any other ideas welcome. Thanks.
UUsee
09-21-2005 06:44:10
 Re: 226 aills engine rebuild HELP ! in reply to 1morgan, 09-20-2005 19:26:13
if you use wd pistons you will have more compression because the wrist pin is .25" lower in the piston.Means it will go up that much higher in the bore.But I could not find any [power crater ] type pistons for WD.If you can find a automotive type piston with a dish and the correct wrist pin hieght go for it,and please post it cause I would like a set also!
mlpankey
09-20-2005 21:24:55
chevy big block truck pistons are the way to go if making a pulling tractor is youre intentions.
BushogPapa
09-20-2005 21:02:29
Be sure to put in the 9 spring pressure plate that is available as a replacement, or you can change the springs, or add the 3 extra springs into your older "WD" clutch... Several companys still sell 4 1/8" kits for the 226 Cu in engine.. Go with a kit that will give you at least 7to1 compression..
Texas Denny
09-20-2005 19:45:44
I believe it is M&W that made the 4 1/8 cylinders. I believe that they made them for the WD-45 as well as for the WD. I know of a source for them. I have 4 1/8 in my WD and I have a WD-45. With the cylinders, the WD is as stout as the 45. If you go with a 45 set, you can expect about 6 horsepower or nearly 50 with a WD-45. My numbers aren't exact. Perhaps someone else .....
