??? How do you remove a WC starter??
Rob in MO
07-21-1999 07:01:53
I need to remove my starter and can't figure out how. All I can see are two nuts in back, nothing near flywheel. Can someone please respond with VERY clear, plain-English instructions? I would really appreciate it!! Thanks, RC
Brian
07-21-1999 11:42:28
 Re: ??? How do you remove a WC starter?? in reply to Rob in MO, 07-21-1999 07:01:53
Looking at the I&T manual I don't see anything on R&R. If its like the B, C, and CA, all you do is remove a bolt and locknut from the side of the casting the starter is mounted in. It should then slide out. The bolt is tapered on the end and fits into a tapered hole in the starter to keep it in place. Hope this helps, Brian
