WD oil filter and spring?
almostdone
10-06-2005 11:22:11
Well I thought I was almostdone. I am having two different problems. 1. I have no oil pressure and have put on a new oil gauge. I have checked the gauge with air and it seems to work fine. I checked the spring and it is ok although showing wear. Where can I get a new spring? Also, a new yarn type filter? Any other suggestions on what I might check? Tractor runs good, no motor noise but I am concerned about the oil pressure. There is oil up in the filter but not filling it. I have checked all the lines and opening to make sure nothing is plugged with dirt etc. Some of you folks are really knowledgeable about these tractors and your help is greatly appreciated by us novices.
scott in illinois
10-07-2005 07:40:41
 Re: WD oil filter and spring? in reply to almostdone, 10-06-2005 11:22:11
Right on about the filters. I bought a B that had a wix filter on it and showed no oil pressure. Changed to a fram c159 and then had good pressure.
Terry(GA)
10-06-2005 15:10:50
You may have the wrong type filter.I use the fram 159 on my wd and it gives it the right amount of back pressure.Alot of the so called replacement filetrs will not work.In my town advance auto has the fram 159 filters,good luck.
Terry (Ga)
10-08-2005 05:29:26
 Re: WD oil filter and spring? in reply to Terry(GA), 10-06-2005 15:10:50
Thank You for the help. I will try the Advance Auto store here in town. Your help is really appreciated.
