wd govenor
aceeman
10-22-2005 17:15:25
Was wondering if anyone could help me figure out why my wd keeps breaking the weights off the govenor. I just bought the tractor with a bad govenor, and repaced the wieghts and ran for couple days here and there, then today I decided to run wide open and the rpm"s built a little slow then the tractor ran wide open, I took it apart again and all the weights are broke off again. Any suggestions. Thanks
mlpankey
10-23-2005 17:30:15
 Re: wd govenor in reply to aceeman, 10-22-2005 17:15:25
the weights very possibly be hitting the case or block housing.youre lucky if its not busting the gear.the weights shouldnt bust till rpm are around2600
Texas Denny
10-23-2005 06:24:08
I think BCnT's answer is reasonable. I can't think of anything else. The rpm should be limited to 1600.
BCnT
10-23-2005 08:17:57
 Re: wd govenor in reply to Texas Denny, 10-23-2005 06:24:08
sometimes ya gotta punt LOL
i hope thats whats wrong with it cause i cant think of anything else either
BCnT
10-22-2005 18:54:28
usually a governed engine has a pre set top RPM...sounds like somebody pumped the rev's up some and the weights arent designed for that much centrifugal force...in other words...the faster the weights spin...the heavier they get.
