Wd Plow Help!
acowner
10-25-2005 14:31:14
I was hoping someone out there had some advice on a 2 Disc disc plow that mounts on the drawbar while still attached. The pump is adjusted correctly for weight transfer and the coulter lead on plow is adjusted. However, plow only goes about 5 inches in ground and will not turn it over. Any help greatly appreciated. Also, this plow has no adjustments on the lift links, they just bolt on.
Butch(OH)
10-25-2005 15:34:02
 Re: Wd Plow Help! in reply to acowner, 10-25-2005 14:31:14
Nobody had them around here, just see them now and then at a show. How is your ground conditions? Seems like lots of new folks try to plow for the first time in there yard, barn yard or some old beat down cow pasture and the older lighter equipment would never go in that type of ground very deep. If you have good moisture and are in ground that has been tilled you have other problems. The few times I have seen disk plows in action was a summer shows and they were doing about what yours is, 6-7" Not much help but all I can offer.
