Plowing Adjustment on Wd Tractor
acowner
10-26-2005 15:26:42
I'm finally getting my disc plow to work alot better. Thanks to all who had suggestions. However, I'm still new to plowing and was wondering exactly how should my wheels be adjusted. The tractor I'm using is a 51 WD.
Butch(OH)
10-26-2005 19:06:11
 Re: Plowing Adjustment on Wd Tractor in reply to acowner, 10-26-2005 15:26:42
Again lacking experiance with that style plow and drawing upon moldboard knowledge I would set the right side wheel tread so that when you have those tires running in the bottom of the last furrow your first disk is cutting the same width as the rear one. Then set the left side wheels to same place.
