Allis B Electrical Schematic
Art Tobkin
12-08-2005 14:48:39
Have to replace the generator on my B. Generator guy said I should go to an alternator and change from a 6 volt to 12 volt system. Hate to lose the orginality of the tractor. Does anyone have an electrical schematic for the 6 volt generator, positive ground system? Also, does anyone have an electrical schematic for a converted alternator 12 volt system? Does going to a 12 volt, negative ground, going to affect the operation of the starter? Thanks.
Greg Ballantyne
12-08-2005 18:49:39
 Re: Allis B Electrical Schematic in reply to Art Tobkin, 12-08-2005 14:48:39
My opinion is stick with the 6 volt. Mine is 56 years old and works fine
steve(ill)
12-08-2005 18:15:23
Dick is right, it is a personal opinion. The 6 volt system is older design, and may be harder or more expensive to get batteries. 12 volt is more common these days. You can go to a 12 volt generator to get the extra boost, and still look original. The alternator is very nice and trouble free, but does not look original if that is important. If the 6 volt is toast and will cost $100 or more to fix, it might be worth considering an update. Dont know if you need any more power, but the 6 volt system will never give more than 8-10 amps output. if you have extra lights or other power draw, the 12 volt systems are a definite plus.
Dick L
12-08-2005 15:30:00
Opinions are like noses, everyone has one. Mine would be to stay with 6 volts. The only opinion that counts is yours with it being your tractor and all.
third party image
