d-17
alc
12-09-2005 07:06:54
i'm wanting to put a two spool hydraulic valve on the back of a d-17 to control two hydraulic cylinders. it only has a hook up for one now with the control on the steering column. can someone help me with what size spool i need, like gpm and psi?
JMS/MN
12-09-2005 16:47:23
 Re: d-17 in reply to alc, 12-09-2005 07:06:54
GPM and PSI is not an issue, as long as you buy parts that can handle the PSI- about 3200psi. Your valve on the steering column provides one-way power. Hook your remote on the tractor to a two valve setup with a return line to the sump. When you need those valves, you need to lock up the integral valve so it feeds your add-on. Then those valves run whatever you need. When not using the add-ons- drop the integral lever to shut off the tractor pump, rather than keep it running and just dumping oil back into the system.
BobHnwOh
12-09-2005 14:52:24
third party image alc,I put this setup on my D17D,left valve runs a one way cyl. the right valve runs a two way cyl,HTH,Bob.
Kevin (FL)
12-09-2005 13:06:55
Do the cylinders have to be indepently operated or both in parallel--both up and both down at the same time?? We bought a D17 that had a control valve on the rear fender--it was used to raise and lower a street sweeper. I think I have photos of the setup before I removed it. Series 1 diesel.
