AC B/C
joe
06-26-1998 06:08:37
Ok AC fans I need a dispute settled. I want to know if the smallest tractor AC made years ago that looked like a IH cub. I was told it was the B & C. The only question I have was; isn't the B & C the same tractor but one with wide front end the other with narrow front end. I was told the B & C are two different models and they both would come with either front end. Help me out.
Dave Richards
06-29-1998 06:54:18
 Re: AC B/C in reply to joe, 06-26-1998 06:08:37
: Ok AC fans I need a dispute settled. I want to know if the smallest tractor AC made years ago that looked like a IH cub. I was told it was the B & C. The only question I have was; isn't the B & C the same tractor but one with wide front end the other with narrow front end. I was told the B & C are two different models and they both would come with either front end. Help me out.
Joe, the AC B and C were analogous To the IHC A and B. The AC tractor which most closely tracked the Cub was the AC "G" which looked nothing like the Cub since it had a rear engine. Cub sike tractors were the AC-G, Massey Harris Poney, JD-L, (Avery had one, Oliver had one, MM and others)
Dave
joe
06-29-1998 07:17:45
 Re: Re: AC B/C in reply to Dave Richards, 06-29-1998 06:54:18
:Thanks Dave, sometimes it is impossible to fiqure out some of these things. I see many cubs, but not many of the other smaller tractors where I am living.
you lost
06-26-1998 20:32:37
