WF fender
Acbear
01-10-2006 18:24:27
I am in need of a right side fender for a styled WF. Would like a NOS, or one that is in very good condition. Is there anyone out there making these fenders? I know that I am asking a lot, but any help would be great. Thank you.
JMS/MN
01-11-2006 09:04:23
 Re: WF fender in reply to Acbear, 01-10-2006 18:24:27
The clamshell is the same as the WC, with some modification. Mounting is different- where the shell is cut out to mount on the WC, that mounting is more forward on the WF, so a wider backup plate is used to cover the open cutout. The curled edge on the lower front is cut off so it fits flat on the mounting plate. Also, The WC fender has two ribs - one forward, one to the rear of cutout. One (forward one?) interferes with mounting on the WF. You can slit that lengthwise, slit an X on each end, hammer it flat, weld, grind, etc to remove the rib. Also weld shut the unused WC mount holes. The small sheet metal bracket on the front of the fender should bolt up to the final drive just like on the WC. I don't know of any source of real WF fenders- could use two of them for mine, so this is what I came up with to use WC clamshells, which are easy to find.
Texas Denny
01-11-2006 06:21:03
I believe that these fenders are the same as those on the WC. Maybe someone else could comment that knows for sure. If they are, there are a lot more WC's than WF's.
