D14 STEERING WHEEL
Al Nelson
01-14-2006 06:15:59
Need some advice on how to remove the steering wheel. Is it splined or press on? I've remove the nut.
Greg (LawlerMinn)
01-14-2006 11:48:45
 Re: D14 STEERING WHEEL in reply to Al Nelson, 01-14-2006 06:15:59
Should be pressed and have a woodruff key. Can be very difficult to remove. Try a good penetrating oil (PB Blaster), let soak and tap back of hub 1st. Try a wheel puller next. Try heat if puller dos'nt do it. Final solution is a cutoff wheel and chisel. Clean well using emery cloth and apply antiseieze to shaft before replacing the steering wheel. Good Luck
