1st project wd
anderson farms
01-15-2006 21:50:15
Just got my wd home today its a 1953 model from the serial number. She's pretty rough, don't run and needs alot of love. But i'm up to the task. First things first I have a milky white fluid leaking out where the PTO shaft goes into a little box under the tractor. Also in front of that I have black oil leaking out. Also its 12 volt not sure if factory, but what alternator does it take? The guy I got it from took it off an old chevy truck. Is there a rebuild kit for the wide front end? I need new bushings and such. Sorry to be long winded just want to get it running before I try and redo it. Thanks for any help
JMS/MN
01-16-2006 08:35:54
 Re: 1st project wd in reply to anderson farms, 01-15-2006 21:50:15
Milky oil means water in the oil. Tractors left ouside, with poor/nonexistent shift lever boots....water gets in, settles in the pto housing. Drain and refill, get a new shifter boot. PTO seals available, can also use pump packing. Front axle bushings are still available at AGCO dealer. www.agcocorp.com for dealer locater. Factory electrical system was 6 volt generator. Best to get an OPERATOR manual to ID controls, adjustments, proper fluids and their locations for drain and fill. Twenty bucks well spent.
