WD Questions
A-C
06-26-1998 11:47:50
I was wondering if crankshafts are interchangable
between a WD and a WD-45? Are the sleeves interchangable?
I am wondering because I am restoring a 1953 WD that has a
bad sleeve and there is a WD-45 sitting next to it that runs great except for a broken crankshaft. The WD-45 has been
used for parts for the WD (radiator, front wheel).
Would it be a good idea to use the 45 engine in the WD if the WD crankshaft would fit?
Thank you very much for any information!!!!
Rob
07-02-1998 09:16:33
 Re: WD Questions in reply to A-C, 06-26-1998 11:47:50
: I was wondering if crankshafts are interchangable
: between a WD and a WD-45? Are the sleeves interchangable?
: I am wondering because I am restoring a 1953 WD that has a
: bad sleeve and there is a WD-45 sitting next to it that : runs great except for a broken crankshaft. The WD-45 has been
: used for parts for the WD (radiator, front wheel).
: Would it be a good idea to use the 45 engine in the WD if : the WD crankshaft would fit?
: Thank you very much for any information!!!!
Yes, I have a 1950 WD with a WD-45 moter and it really works out nice!
jbaker
06-26-1998 12:16:32
yes I once put a wd45 crank in a wc block sleeves and pistons work too. one rod will have to have the bolt filed a little because it is very close.
