More WD problems!!!
anderson farms
02-05-2006 22:26:10
Rebuilt the zeinth carb put it back on and the gas still leaks out at the main jet and the little hole on the bottom. Any ideas? Also does anyone have a picture of the fuel line? My fuel line is really cobbled up and I don't know how it is to be ran. Also can't get the choke linkage to work if I disconnect it it will move freely but it binds real bad when hooked up. Do I need to buy a new carb or send it off to be rebuilt? Thanks for any help
old
02-06-2006 08:38:57
 Re: More WD problems!!! in reply to anderson farms, 02-05-2006 22:26:10
If it has a rubber tipped float needle heres a thing to try. Open it back up, remove the float and then drop the needle back in the seat. Make sure the seat is good and tight first because that can also be your problem. Then with the needle in the seat tap on the needle a couple times with a small hammer or something like that. What that does is sets the tip of the needle. Got that from an old crab guy that has long since died
