'51 Allis-Chalmers WD--Positive or Negative Ground?
MJMC
06-29-1998 10:51:21
Does this tractor utilize a positive or negative ground? Thank you
lou mccarrell
09-06-1999 16:37:02
 Re: '51 Allis-Chalmers WD--Positive or Negative Ground? in reply to MJMC, 06-29-1998 10:51:21
: Does this tractor utilize a positive or negative ground? Thank you
by now you probably know it is a neg gnd system, and fyi, if you want, a gm alternator, can replace the generator, and replace the battery w/a 12volt. the 6volt starter will handle the 12volts just fine!
lou mccarrell
09-06-1999 16:32:16
lou mccarrell
09-06-1999 16:31:22
grapeape
06-30-1998 06:53:08
positively a positive ground, but if you convert to an alternator you must reverse the polarity
MJMC
07-01-1998 07:32:57
 Re: Re: '51 Allis-Chalmers WD--Positive or Negative Ground? in reply to grapeape, 06-30-1998 06:53:08
: : Does this tractor utilize a positive or negative ground? Thank you
: positively a positive ground, but if you convert to an alternator you must reverse the polarity
Thanks for the feedback. That's the way I have it, but the battery was removed for quite a while, and I thought perhaps that was the starter problem. Can't get it to turn over. Will keep on the hunt...
