5040 lift problem
allis 5040
03-17-2006 16:03:58
I feed with my 5040 every day. Today the 3pt lift lever is so stiff I"m afraid it will break.I can"t see any reason on the outside. What could cause this?
geok
03-18-2006 06:13:50
 Re: 5040 lift problem in reply to allis 5040, 03-17-2006 16:03:58
If memory serves me, the 5040 is a Fiat design tractor. The lift control is about the same as the Long tractor. It is a common problem from being exposed to weather; the shaft starts binding up in the bushing. I have not had much luck spraying penetrating oil such as WD40 to help loosen up the problem. You will probably have to remove and disassemble the control unit. Use sand paper on the shaft and bushing. When you put it back together use water resistance grease.
allis 5040
03-18-2006 08:37:32
 Re: 5040 lift problem in reply to geok, 03-18-2006 06:13:50
Thank you for the reply. I just fed this morning and I could barley get the lift lever to move. I'm going to get a book and start on it.
