Allis B Oil pressure
Albertagary
04-14-2006 20:15:41
How much oil pressure should a Model B Allis have? Idle, and wide open.
Thanks Gary
wdtom
04-16-2006 17:29:58
 Re: Allis B Oil pressure in reply to Albertagary, 04-14-2006 20:15:41
But don't worry if you only have a little, as long as the needle moves you are OK. I have seen them run with the needle only up to the lower line of normal when cold and barely move when warm. If the bearings are worn this can happen, expecially the camshaft bearings as the oil goes through the camshaft to the other bearings. All you need to do is make sure you have flow and not worry much about pressure.
jeffalex2
04-16-2006 04:34:07
Mine always read about 15-18 before I put the Allis imitation gauge back on it that just says 'normal'.
1755
04-18-2006 14:56:59
 Re: Allis B Oil pressure in reply to jeffalex2, 04-16-2006 04:34:07
Just wandering what letter in normal it points at one of our CAs runs at 15psi or so all the time the other runs from R to berly past the normal mark when hot Thanks
steve(ill)
04-15-2006 20:23:18
a B in very good condition will have 15 psi when cold. when hot it will drop to 10-12 psi. mine holds 10 psi at an idle when hot. you should ahve over 5. less than that and you may have some troubles coming.
old
04-14-2006 20:40:28
My B holds about 20 PSI wide open and maybe 15 PSI at Idle
