wide front D-17
504
04-17-2006 21:41:54
The tractor has a Swartz wide front but it doesn`t turn short enough,it took three trys to get it in the barn. Anybody have an idea? Thanks 504
Texas Denny
04-19-2006 10:15:16
 Re: wide front D-17 in reply to 504, 04-17-2006 21:41:54
A lot of the early wide fronts had a very poor turning radius. There may be a problem or it may be design. You could start by disconnecting the tie rods. Jack up the wheels one at a time and check to see how far they turn in each direction. Then rotate the steering wheel to determine if the steering goes beyond normal. Then, re-attach the tie rods and see where the stop is.
