wd sounds like a lawn mower
alliswdman
04-17-2006 22:29:42
i have awd allis i switch over dist. beecause mag. went out on me i set the timing on all the marks like the book told me and it started fine but it sounds like its not hitting on all 4 pulled out spark plug wire one at a time and found that the 2 middle cylinders are noy hitting my friend said the dist. turns clock wise but the book says counterclock wise so do i follow the same fire order on engine as on dist.? or is it 1234 from the fan or is it 1243 from the fan? i am lost never had this problem
Jim E NE IN
04-18-2006 19:32:05
 Re: wd sounds like a lawn mower in reply to alliswdman, 04-17-2006 22:29:42
I would also replace the plugs with Autolite 295. I had the same issue and that's all I ended up needing.
alliswdman
04-18-2006 17:52:22
i switch the 2 wires and it sound graet thank you all for your help
John (C-IL)
04-19-2006 05:35:12
 Re: wd sounds like a lawn mower in reply to alliswdman, 04-18-2006 17:52:22
Thanks for reporting back, it's always good to hear what the solution to a problem was.
Bob
04-18-2006 20:24:53
GOOD JOB!
old
04-18-2006 07:00:53
I agree with BOB I would switch #2 and #3 and see what happens the least it could do is run right. The only other thing I know that could be wrong is you have a bad cap and or rotor. Or if its a used distutor the bushings in it could be bad and it doesn't open the points in those to places. But I would bet its that you have 2 and 3 switched
John (C-IL)
04-18-2006 04:57:19
I'm confused. But the firing order is 1243. The results are the same whether you start from the front or the back, but convention is to start in the front (radiator end). I agree that you may have the wires on 2 & 3 crossed.
alliswdman
04-20-2006 22:19:33
 Re: wd sounds like a lawn mower in reply to John (C-IL), 04-18-2006 04:57:19
i have a wc tractor with no motor and radiator but most of it still in one piece can i put a d17 gas engine in that wc and have no problemsi,m thinking that if a d17 engine is a 226cid than should work fine i do not know about flywheel matching up to trany. a wd45 has same 226cid also so it should work plaese help
Bob
04-18-2006 01:31:10
It's REAL simple to determine distributor rotation... take the distributor cap off, crank the engine a bit, and OBSERVE which way it turns.
Cylinder numbering is 1234, front (radiator) to back.
Try swapping the spark plug wires from the two cylinders that are NOT firing.
