D-14 ring gear
allis_steve
04-22-2006 01:03:11
Any idea where I can get a new ring gear for D14 (93 tooth)?
Phil Auten (TX)
04-24-2006 10:46:30
 Re: D-14 ring gear in reply to allis_steve, 04-22-2006 01:03:11
Steve,
If your current ring gear isn't broken or chewed up real bad, you can remove it and turn it over for a fresh gear mating surface. A little work, but you're going to have to remove the old ring gear anyway if you replace it, so why not just reuse the old one?
Phil
Allis Steve
04-25-2006 03:36:23
 Re: D-14 ring gear in reply to Phil Auten (TX), 04-24-2006 10:46:30
Great idea but it has already been done. Thanks for the reply. Steve.
Kent of SW MO
04-22-2006 05:17:32
Ring gear should not be replaced by itself. The ring gear and pinion are a matched set. They should both be replaced. This matched set of gears must also be set-up properly as in pinion depth and ring gear backlash.
Kent
allis steve
04-22-2006 05:23:07
 Re: D-14 ring gear in reply to Kent of SW MO, 04-22-2006 05:17:32
I am sorry that I did not explain the ring gear better. It is the flywheel ring gear. Thanks for the reply though. Steve.
