AC 2 bottom plow questions
Steve in S IL
04-30-2006 10:39:44
third party image
I recently acquired an AC 2 bottom plow, which is missing a coulter. I have the arm for the coulter I recently acquired an AC 2 bottom plow. (Which is missing a coulter) I have the arm for the coulter and I think I have located a coulter to fit. Where do I find a serial number on the plow? I bought this plow to use on my CA. I was able to hook it up to move it, but I know this is not correct. (See my attempt in the picture.) Does anyone have a close up picture of how this is supposed to connect? Or a few pages out of a manual that can help me? Any help will be greatly appreciated.
Thanks,
Steve in S. IL
Dale Garver
05-02-2006 07:31:08
 Re: AC 2 bottom plow questions in reply to Steve in S IL, 04-30-2006 10:39:44
Steve get hold of me I might have what you need.
Dakota Dave
05-01-2006 05:38:12
THe CA with out the Snap coupler that that plow was designed for has lift arms that are 6 or 8 inches longer.
chalmersbob
04-30-2006 18:22:28
your plow is just called "ca pick-up plow"
the model you have was designed for the pin connector under ther tractor, before snap coupler.
the lift arms of the older ca tractors have two holes for the u shaped pin (lift pin) on the bracket. the pin comes out and the bracket(yoke) lays flat on the bottom of the arms, and the u pin inserts into both holes. i have the manual, but it doesn't have any good pictures.Bob
JMS/MN
04-30-2006 13:07:28
This is just a wild guess, since I don't recognize the links you are using to attach the plow- I just figured there was a spring latch like on the WD45 plows. I see a flat surface on the right side mount, (top side). Similar flat might be on the bottom side of the left mounting. Question is- there is another hole midway on the mounting- if you attach the mount to the underside of the lift arm, flat would be underneath, and put the bolt in the middle hole- wouldn't it raise the plow higher?
Jerry Coulter
04-30-2006 11:03:17
AC plows don't have serial numbers. As best I can tell, you have a 50 series plow, called a 52 if it has 2 bottoms. The 50 series has the beam running perpendicular to the frame while the newer 60 and 70 series has the beam slanted forward. I believe the coulters are pretty much interchangeable from one plow to another.
