GEAR DRIVE ON INJECTOR PUMP
52 g
05-18-2006 10:28:03
Can the gear drive on a 190XT series 3 that drives the injector pump move enough with pump off to get out of time. I removed pump, had it rebuilt and put back on, now it want run, it seems out of time. Could i have moved the drive shaft enough for it to have jumped one notch. Thanks for any help.
Joe(TX)
05-18-2006 14:58:44
 Re: GEAR DRIVE ON INJECTOR PUMP in reply to 52 g, 05-18-2006 10:28:03
If you pulled the pump off, you need to retime it. Theres no way around it. You may have the pump 180 deg out of time. Theres no way around it. The proper removal proceedure is to take the cover plate off the timing cover, remove the gear and shaft, and then remove the pump.
Install by putting the timming mark on the crank to the proper advance with #1 on compression, and intall the pump with the pump timming marks lined up. Then install the gear and shaft. The pump also can ge rotated some to get the exact timing.
