what resistor can I use in place of light switch o
28sstony
06-05-2006 07:19:14
I dont plan on ever running lights, what resistor do I need to wire in place of the switch?
28sstony
06-06-2006 05:56:06
 Re: what resistor can I use in place of light swit in reply to 28sstony, 06-05-2006 07:19:14
so I need one of theese?
http://www.mcminone.com/product.asp?catalog_name=MCMProducts&product_id=48-3&CMP=datafeeds&ATT=froogle
jeffalex2
06-06-2006 18:59:10
 Re: what resistor can I use in place of light swit in reply to 28sstony, 06-06-2006 05:56:06
If you look at the specs on that one, it's 5" long...be tough to fit in the housing...I guess you could mount it outboard somewhere...or try this one:
http://www.electronicplus.com/content/ProductPage.asp?maincat=RE&subcat=REH
jeffalex2
06-05-2006 17:43:01
The resistors are in series with the charge circuit for standard low charge...the light switch just created a short around the resistor for high charge. SOME auto parts stores have high wattage/low resistance wire wound resistors to rebuild heater fan switches. When I re-wired mine, I replaced the light switch with a triple pole/triple throw switch and made position 1-std charge with resistors / position 2-std charge and lights on / position 3-high charge no lights. I got the wire wound resistor here in Baltimore at a place called Baynesville Electronics. I thought I'd could do without my lights too...I was wrong within 2 months
steve(ill)
06-05-2006 16:05:40
some guys wind their own, but what i would do is buy a 10 ohm, 10 watt and connect 3 together in parallel. i bought them at RS for $1 each to use on the Delco alternator conversions. in parallel that would be 10/3 or 3.3 ohms and 30 watts
Rod (NH)
06-05-2006 16:57:20
 Re: what resistor can I use in place of light swit in reply to steve(ill), 06-05-2006 16:05:40
Hi Steve,
I believe you are incorrect on the equivalent resistance of 3.3 ohms in your example. The equivalent resistance for multiple resistances in parallel is the reciprocal of the sum of the reciprocals of the individual resistances. In other words, for three resistors in parallel, 1/Req = 1/R1+1/R2+1/R3. That would make three 3 ohm resistors in parallel equal to 1 ohm, not 3.3 ohms.
third party image Rod
Rod (NH)
06-05-2006 17:26:25
 Re: what resistor can I use in place of light swit in reply to Rod (NH), 06-05-2006 16:57:20
OOPS! Sorry Steve, you are in fact correct at 3.3 ohms using three 10 ohm resistors in parallel. I was thinking 3 ohm resistors instead. I should have read your post more carefully.
Rod
28sstony
06-05-2006 10:22:02
Sorry, I didnt realize that half of the title got cut off.
I need to replace the defective light switch/resistor on my model C and didnt want to buy a 70 dollar switch when a cheap radio shack part will do what I need, I jsut wasnt sure exactly what resistor I needed.
Thanks.
Joe(TX)
06-05-2006 10:01:53
What is it on and what are you trying to do?
A switch is just on and off. Just don't connect the wire and it's off.
Ted In NE OH
06-05-2006 10:01:10
for low charge use a 3 ohm 25 watt
Butch(OH)
06-05-2006 13:13:08
 Re: what resistor can I use in place of light swit in reply to Ted In NE OH, 06-05-2006 10:01:10
Ted, 3 ohm, 25 watt OK so where does a person purchase one of those, any ides? Radio shack says, ya right. Lots of three ohms from about 1/2 watt on down.
